- Mute
11-12-2021
07:21 PM
(Last edited
11-30-2021
05:49 PM
by
SamsungJoJo
) in
I have the note 10 plus and it won't connect to wifi even after restart, reset and reset of router
- Mute
11-13-2021 05:55 AM in
Note10If it doesn't, there may be a configuration error on your home network.
- Mute
11-15-2021 09:31 AM in
Note10if MochaVex's suggestion did not help figure out the issue, then try Network Reset from the setting please. You'll need to re-setup the BT and WIFI you had before.
- Mute
11-16-2021 03:54 AM in
Note10
