Bobbydrakes
Cosmic Ray
Note 10+ power mode problem
JUMP TO SOLUTION
guys . good day!!
i usually set my power mode  to medium power savings also turn on the adaptive power savings...
after removing the charger from the phone .. automatically the power mode goes off.. its annoying to turn it back on.. hope u guys have a fix for this
Need help .. Smiley Sad
1 SOLUTION
Samsung Care Ambassador
Re: Note 10+ power mode problem
JUMP TO SOLUTION
@Bobbydrakes  hello! 🙂
While using adaptive power saving, your phone will automatically change the power modes based on your usage.
5 REPLIES 5
JUMP TO SOLUTION
Have you tested the phone in Safe Mode to see if the power mode changes?
Bobbydrakes
Cosmic Ray
JUMP TO SOLUTION
already tried safe mode.. didnt fix the problem./bug.
JUMP TO SOLUTION
If it still happens when your device is in safe mode I would recommend having the phone evaluated by a certified technician. You may have two options for this depending on your location. You can either visit a local uBreakiFix location or you can ship your phone into the Samsung service center.
JUMP TO SOLUTION
Bobbydrakes
Cosmic Ray
JUMP TO SOLUTION
true.. but my issue is that .. i already set my phone to medium power saving.. but after charging the phone .. the powersaving mode turns off.. doesnt happen on my s8 plus .. or even on my s7 edge..
