user0cvcECJVei
Notification and sound issues
Im having problems with notifications or sound for a few apps.  Facebook and Facebook messenger are either extremely loud or make no sounds at all. I have notification volume on the lowest setting before off and it's either louder than acceptable or no sound at all. I have tried turning on ignore DND and that didn't seem to help as it did my old S8.
Discord won't play through the speaker unless I disable bluetooth.  This is an anoyance as I have a gear S3.
What can I do to solve these problems?
2 REPLIES 2
Re: Notification and sound issues
Do you experience these symptoms using the stock apps?
ChampagneOppa
The master sound is controlled through tour sound option...
The master sound is controlled through tour sound option in your phone. Maybe try setting all your apps to the default tone and volume through your phone options.
