TheGrandMaster
Cosmic Ray
Notification sound when silent is infuriating.
Whenever I out my phone on vibrate or silent, especially during a call, I get notification sounds still playoffs whenever I get a notification. Because my call volume is up my ears get blasted with Orion sounds Everytime. Any clue as to how to stop this.??
5 REPLIES 5
Samsung Care Ambassador
Re: Notification sound when silent is infuriating.
Is there any exceptions in the settings?  That would allow certain apps to override the DND and silent profile
TheGrandMaster
Cosmic Ray
I have absolutely no apps that are able to override DND. Strangely this only happens during a phone call which is when my headphones are on and the notification sound is blasted into my ear.
Honored Contributor
Look in the phone app's settings.  So go to phone app, tap 3 dots on top right, then settings, then "call and alerts and ringtones", then look at "notify during calls" there is a toggle switch
TheGrandMaster
Cosmic Ray
@Charkatak thanks that's exactly the issue. Found a new menu to look at thanks.
TheGrandMaster
Cosmic Ray
Solution didn't work long term and came back actually. What's up?
