userieRt5Au4aa
Notification sounds won't work.
JUMP TO SOLUTION
I have tried just about everything i can think of but i cant get the notification sounds for messages to work. The notifications for everything else work i.e whatsapp. I have tried changing the tones, enabling messagers app, changing the tones through the app and settings. I have tried changing watch setting. Everything i can thing of. Any ideas?
1 SOLUTION
userieRt5Au4aa
Re: This happened to me and I went into every setting unable...
JUMP TO SOLUTION
@Samsung_l134Rxj wrote:
This happened to me and I went into every setting unable to figure it out. Finally, one day, by accident, I finally found what happened and how to fix it. Go to your messages and click up on the volume button. At the top of your screen you will see a pop up saying "in call volume." Pull down on the little dash bar to expand that section (see my pic attached and pull down where you see I have it circled). See my next pic showing the notifications volume and here is where you can reinstate your notifications volume so they're no longer silent or vibrate only. 🙌🎉
I finally figured it out. It wasnt that. I kept changing the tones in the message app not realising there was two message tone sections. I was changing general notification and didnt even realise (feel like an id#ot), just under it was another tab saying new messages. I thought it was to do with reports and all that so i never clicked on it. Turns out it also had tone selection and it was on silent.
Thank you for the help though guys. I do appreciate it.
6 REPLIES 6
Re: Notification sounds won't work.
JUMP TO SOLUTION
Which device can you not hear the notifications with?
usermz6RgtaqPu
Samsung galaxy note 8
JUMP TO SOLUTION
JUMP TO SOLUTION
Can you hear the notifications if you have the device in safe mode?
Samsung_l134Rxj
JUMP TO SOLUTION
userieRt5Au4aa
JUMP TO SOLUTION
userwBPUgavnVt
JUMP TO SOLUTION
Oh my gosh, thank you!!  This is what was wrong with mine also!!
