Showing results forΒ
Search instead forΒ
Did you mean:Β
userg04LrtLbMq
PS4 controller connection issues
My ps4 controller connects to my note 10 plus but does not input anything I do in the control. Why is this happening?! Am I missing somthing? Please fix or I'll have to downgrade to iPhone 😭😭 expensive phone and cant use a control? Anyways I'm with tmobile
4 REPLIES 4
Samsung Care Ambassador
Re: PS4 controller connection issues
Hey @userg04LrtLbMq, I hope you're doing well.
Can you please provide me with your current baseband version? This can be found in: Settings>About phone>Software information>Baseband version.
I don't have a PS4 controller to test with but I do have an Xbox One controller that's paired and working 100% fine.
I have done a bit of reading and if you have the dualshock controller, you'll need to wait for Android 10. Android 10 for the Note 10 may soon open up for official beta. Have you tried connecting your controller directly via USB?
Best regards,
Rydah
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "βœ“ Accept as Solution" button.
Samsung_TE7rss3
I have tried steel series , Xbox , PS4, all tethered and Bluetooth none will work after the remote play app is open.
user7jY1PmpFX5
Hi @Rydah
Android 10 answer makes no sense. This was an observed issue with S10 and was then later patched in May of this year, and then again for an A model.
The android 10 has nothing to do with this, I believe that is for PS4 remote play support, here we are talking about basic controller connectivity as an input device.
Why have the devs not been able to patch this yet? esp, when it was already encountered with S10??
RidiculousRhino
I believe Playstation said that DS4s will work with Android 10
