Phone battery drains faster than it can charge
(Topic created: 11-25-2019 02:04 PM)
KatsGraphics
Galaxy Note Phones
I keep getting the notification that my phone battery drains faster than it can charge. I've cleared out my app tray, and it's fast charging. Any thoughts?
The-dino
Halo
Galaxy Note Phones
Enable power saving mode (preferably mid-tier), turn off Bluetooth and stop using it while charging
The-dino
Halo
Galaxy Note Phones
KatsGraphics
Galaxy Note Phones
I have it on mid tier power saving, and I don't use it too much (message here and there, maybe Discord) but I'll turn bluetooth off, thanks
Samsung_QSEb9d0
Galaxy Note Phones
battery sounds like it needs changeing
userPvWoeVcSQK
Galaxy Note Phones
Fast charge degrades battery much faster. So this maybe the reaaon
Phantom
Comet
Galaxy Note Phones
Is it possible that the wire/outlet has been damaged? This is indicated for me as well sometimes if something's wrong with the charging cable.
