userjeFuDSlMou
Phone not ring with led cover closed
I have a new Note 10 Plus phone and a new Samsung Led cover (https://www.samsung.com/uk/mobile-accessories/led-view-cover-galaxy-note10-plus/EF-NN975PBEGWW/). If I have the case cover closed, Google voice call will not ring on the phone. If the cover is open, the phone does ring. But if I call the SIM number, phone does ring both ways. What can be done?
6 REPLIES 6
Re: Phone not ring with led cover closed
@userjeFuDSlMou Does this issue still persist when your phone is in safe mode?
userjeFuDSlMou
At safe mode, it does ring
If it works correctly while the device is in safe mode that typically means there is a third party application that is causing some kind of interference.
userjeFuDSlMou
It is the case. If I have the cover open, it rings.
userjeFuDSlMou
Can someone tell me if it's an issue with this case or it is with any of this production?
user4Ldku9i9mx
Did you try a factory reset?. My note 10 goes straight to voicemail. My carrier Sprint said take the phone back.
