user2leSXafDlH
Poor battery life Note 10+
Has anyone else experienced poor battery life on their Note 10+? It will drop to 10% or more after a half hour of light use. I came from an iPhone XR and the battery life is awful in comparison and the Note has double the capacity.
3 REPLIES 3
userHiH2gRH3A6
I have not had this experience... I have had quite the op...
I have not had this experience... I have had quite the opposite where I enjoy seeing how long I can go unplugged. I lasted almost 2 days on the first charge and didn't charge last night and was only at 60 percent and I was watching videos for about 2 hours before falling asleep.
I think you have an issue.
user2leSXafDlH
Thanks for the reply. And it should say it drops 10% or m...
Thanks for the reply. And it should say it drops 10% or more in a half hour of light use. It is not dropping all the way down to 10%.
user2leSXafDlH
Also may I ask if you have an unlocked or carrier locked...
Also may I ask if you have an unlocked or carrier locked device?
