08-30-2019 02:09 PM
Today, I was using my phone like every other day, until at one point, the phone's vibration started to get weak, 10 to 15 seconds, the vibration just died. I've checked every little setting to see if it was messing around with it, all settings were fine. I contacted Samsung Support, they've tried to help me, and things they told me to do is Resest setting (Made it where it can vibrate but it's still really super and died after 10 seconds). Then they told me to "wipe cache partition" (didn't work) The last thing they suggest is Factory reset, but before I do, I want to see if anyone in the community have a solution.
08-30-2019 08:32 PM
Update* I've Factory reset my note 10+ (still didn't work) most likely a hardware issue than a software issue. Still upset that the motor didn't last long..
09-04-2019 11:09 PM
Same issue however, mine just died no warning. I did all the same things no luck.
09-04-2019 11:27 PM
I just bought the note 10 plus as well and I'm not sure if I have ever really felt it vibrate. Kinda stinks bc if it's on silent mode I don't know whether or not I have missed notifications.
09-08-2019 07:38 AM
and i really have a problem. is there a solution
09-08-2019 01:09 PM
@user7Y05xcCZ82 Has your phone stopped vibrating all together?
11-11-2019 01:35 AM
Am havin same issue, my note 10 plus stopped vibration entirely after the last update. I have tried the various ways to test the vibration but non of them worked, I also tried wiping cache but still not working, how can this problem be resovled?
11-11-2019 08:55 AM
@userv4b3skO4QV Can I please have your full model number and IMEI in a private message: http://bit.ly/2JH2rq2
09-08-2019 08:34 AM
The vibration on my Note 10+ is very light or weak, compared to my older note models.
09-08-2019 08:56 AM
Mrfreebro, I would take it to ubreakit
