Highlighted
Stylus won't connect to Note 10
I had to replace my stylus and now cannot connect the stylus to my phone.  It is a certified stylus for the Note10+. Does anyone have any idea what to do?
3 REPLIES 3
Highlighted
Cosmic Ray
Re: Stylus won't connect to Note 10
Where did you buy it?
Highlighted
Cosmic Ray
If you bought it from anywhere other than Samsung or major retailer that sells actual Samsung accessories its likely a fake. A lot of places sell ones that are compatible and will function as a pen but they don't have Bluetooth.
Highlighted
Bluetooth devices give you tons of flexibility, and the S Pen on Galaxy Note phones are Bluetooth compatible! This includes the Note20 5G and Note20 Ultra 5G, which include the most streamlined and customizable S Pens yet. The S Pen is no normal pen and it doesn’t use normal Bluetooth. It's a special kind of BT that will let you pair, charge, and reset the Note's innovative S Pen. Give this link a try:
https://www.samsung.com/us/support/answer/ANS00080375/
