Temp too low wont charge Note 10
(Topic created on: 1/1/21 8:08 AM)
useraagHXmSdFS
Note10
Thus is the 2nd time its happened and its already been too samsung too fix, worked fine for a few months then did the same thing again, when rang told they will re-fix it under warranty, however as I now have a crack on my screen they will not fix the battery issue without me paying them for the screen too be fixed at the same time, and when they fix the screen they swap out the battery anyway, so what they are now saying is that we will fix the issue for the 2nd time, but it will now cost you £250, so much for a warranty
