Highlighted
Where is the dual audio setting on Bluetooth for Galaxy note 10 plus
where is the dual audio speaker setting on Bluetooth for Galaxy note 10 plus
1 REPLY 1
Highlighted
Re: Where is the dual audio setting on Bluetooth for Galaxy note 10 plus
download
http://apps.samsung.com/appquery/appDetail.as?appId=com.samsung.android.soundassistant
it has every audio settings you need even the dual audio
you can control the volume to both of your bluetooth devices, one could be at 5 and the other at 10 if you are doing separate apps
