do I need qualcomm quick charge to charge 25 watt and up?
Do you need a charger with qualcomm quick charge to charge the note 10 plus 25 watt and up or can you just buy a normal charger with the same wattage?
2 REPLIES 2
Re: do I need qualcomm quick charge to charge 25 watt and up?
need help connecting my phone to my radio
Galaxy
Uhh theres a few youtube videos I recommend you watch that will have the best results for the battery. what they basically say is since the battery is higher watt you should get a cord/block that can do the same wattage and/or higher or else it could damage your battery longterm. If you search up Note 10+ battery cords and look at the videos then that should give you some info
