11-25-2020 11:08 AM
11-30-2020 08:43 AM
Thank you for reaching out. Have you tried clearing the cache for the edge panels?
Give these steps a try: Go to settings > apps > edge screen > tap on force stop > then tap on storage and clear the cache
Next, I would recommend wiping the cache partition on your device. The system cache partition stores temporary system data. It's supposed to allow the system to access apps more quickly and efficiently, but sometimes things get cluttered and outdated, so a periodic cache clearing can help make the system run more smoothly. Give these steps a try:
