Highlighted
galaxy note 10 plus camera horrible low light photos
Ok so yesterday for July 4th celebration my note 10s camera took low light night camera horrible when I switch to wide mode when I'm recording after the few two updates my camera was working flawlessly until the two updates ruin the camera i mean its no very bad either but I think it needs to be updated or something i was where there was light and my camera wouldn't capture what's going on around me beside the fireworks not sure if its a software issue hope samsung takes a look into this
2 REPLIES 2
Highlighted
samsung note 10 plus camera
Also it heats up while using the camera on my note 10 plus not sure if it's the phone or the camera it heats up a lot note sure if thats normal or not
Highlighted
Samsung Care Ambassador
Re: samsung note 10 plus camera
When using the camera, especially while video recording the device will heat up due to the processing power your CPU is under. This is why most Android devices will have a 4K60FPS recording limit (usually between 5-10mins) due to the heating issue when recording in that higher resolution.
