Highlighted
sim connection problem
Samsung Galaxy Note 10 Plus (SM-N975U1) My phone gives a sim card not read error and can never be connected. Does anyone know the solution to the problem? What should I do?
1 REPLY 1
Highlighted
Supernova
Re: sim connection problem
@Samsung_N9fH0Il did you just get this phone or is this a new error and was previously working?
Some routine troubleshooting may help as well: remove the SIM, reinsert, reboot the phone, and then try updating your network connections from Settings.
Did this reply help? Be sure to click" ✓ Accept as Solution" if you found this reply solved your issue or pointed you in the right direction. You can also click the heart to let me know your appreciation!
