AKG earbuds bad sound quality
(Topic created: 06-09-2021 03:19 PM)
RyanB
Note20
So I just bought the type c AKG earbuds because I was tired of using a dongle for my earbuds and I'm always having major problems with these earbuds. The audio and microphone quality are so bad, there is white noise and static in the earbuds and the microphone barely even works and nothing online has a solution to fix this. On top of that I can't turn on the UHQ option even though I have the earbuds plugged in. Is there a way to fix this???
Andytheman
Comet
Note20
Return them for new ones or a refund. If you want you can speak to Samsung but if their that bad, they're toast.
userdfpX8y1HDA
Note20
Yes there is. Return them and get some better ones.
