Auto rotation problem when using Notification panel
(Topic created: 06-09-2021 02:36 PM)
userkGUYU6WJ58
Cosmic Ray
Note20
Hi everyone,
My note 20 ultra is auto rotating when I use notifications bar while I am using the phone in the landscape mode even I stop the screen auto rotation mode.
Does anyone have idea about this problem and how to fix it?
Thank you in advance.
userdfpX8y1HDA
Note20
You might try going into your camera settings.
userLxr3xpANnM
Note20
Open quick panel and auto rotation.Screenshot_20210610-012042_Samsung Members.jpg
MrJell_Lee
Nebula
Note20
yall, this guys said he stopped the auto rotate mode...
@userkGUYU6WJ58 If you have the auto rotate disabled and still seeing the screen rotate when you didn't initiate the rotation, then submit and issue report using Samsung Members app right after you see it happen again. It would be best if you are able to capture a screen recording of it happening (there's a screen record feature in the quick panel).
