Battery dying
(Topic created: a month ago)
userJx5zAbXVsZ
Note20
I've had the note 20 ultra about a year, and suddenly this week the battery drain is crazy. Doing the same apps and basic usage as previously, it's gone from about 40% remaining at the end of the day, to dropping down to about 20% before noon, again by 5pm, and again before bed. I've even turned on battery saver, with minimal change. My battery has dropped 5% in the couple of minutes to add this post. In a week I've gone from loving this phone, to wanting to lose it to claim the insurance. Is anyone aware of any apps or updates that have occurred in the last couple of weeks that might cause this?
Note20
Just use an application called Good Guardians. It has good tools to optimize your phone's experience
Note20
Check the app store and look for the recently updated apps... check the battery optimizer and see what's using it the most
TheGalaxy
Neutron Star
Note20
How do you normally charge it?
Fast? Wireless? Regular?
Note20
Try performing a partition cache clear to clean out any software bugs or old, corrupt files and reboot your phone.
Note20
Sometimes after a year of use the battery drains a lot quicker.
