Best 15 Watt Wireless Note 20 Ultra Charger
(Topic created: 08-11-2020 06:02 AM)
useranUlNphuTK
Note20
What are the best subject chargers available? Thanks for any recommendations.
JohnLoose
Supernova
Note20
@useranUlNphuTK @Geno71
This Samsung charger is compatible with S20 Ultra so I'd bet it works with the Note 20 as well.
https://www.samsung.com/us/mobile/mobile-accessories/phones/wireless-charger-stand-15w-black-ep-n520...
Did this reply help? Be sure to click" ✓ Accept as Solution" if you found this reply solved your issue or pointed you in the right direction. You can also click the heart to let me know your appreciation!
Geno71
Samsung Care Ambassador
Note20
@useranUlNphuTK
I always go with official Samsung wireless chargers. I tried other brands before, and they were causing issues. Not all the time, but sometimes the phone wouldn't charge on them.
Don't forget to give this post a Like by clicking on the ❤ icon below.
And if it answered your question, please click on "Accept as Solution"
useranUlNphuTK
Note20
@Geno71 wrote:
@useranUlNphuTK
Thanks for your input. I had a phone destroyed by an off-brand charger. Does anyone know if Samsung is coming out with a new 15W wireless charger that is compatible with the Note 20 Ultra?
JohnLoose
Supernova
Note20
MeadeR
Note20
use a barrel charger for hp touch pad web so 2.1amp 5.2 v
