Connect car radio thru USB
(Topic created: 06-13-2021 12:45 PM)
userWGzmyCQMdv
Note20
Why will my Note 20 not connect to my car radio thru USB? My son's iPhone connects fine and streams whatever he wants, this is VERY frustrating! Tried the debugging thru developer options and audio is not an option. I'm not sure why Samsung won't allow us to stream our phone to the radio like Apple does without issue
linda1962
Note20
Try going thru Bluetooth. See if the Bluetooth works and make sure the Bluetooth is on. Using Bluetooth works better.
Adaboy
Red Giant
Note20
When you plug it in does the phone give you options on how to use the phone. IE storage, multimedia
userYH8Z5rlNsv
Cosmic Ray
Note20
My Note 20 connects thru type C and changing my stereo to aux
EnumC
Note20
Check your notification area. There should be a banner titled "Android System", and it most likely will say "Charging this device via USB". You have to tap that and switch to MTP or PTP.
