- Mute
- Email to a Friend
01-06-2021 12:41 PM in
Note20Bought a fast wireless charging pad (slim) from the Samsung store for my Note20, it worked fine for a month, but now It seems to charge at regular speeds and no more fast charging. Tried every measure possible from the restarts , changed my charging points , no software updates to be found (till the date this has been posted). Any solutions ?
- Mute
- Email to a Friend
01-06-2021 02:15 PM in
Note20- Mark as New
- Mute
- Email to a Friend
01-07-2021 11:46 AM (Last edited 01-07-2021 11:47 AM ) in
Note20are you using the Samsung stock fast-charging brick? also, is fast charging enabled in the settings?
- Mute
- Email to a Friend
01-07-2021 12:16 PM in
Note20Fast Wireless Charging is a setting that may have ben toggled off by the Android 11 software update. Ensure this is enabled.
Settings | Battery and device care | Battery | More battery settings
Fast wireless settings (to the right is on)
