Highlighted
Galaxy Note 20 Super Slow Motion is not able to focus
The super slow motion setting on the note 20 does not have the ability to focus. It has a pre set focus point and theres nothing you can do to change it. However every other setting has the ability to change the focus point. Apart from that. You cant change the amount of time the phone shoots at one time. Its stuck to .8 seconds of super slow mo. The option to change it simply isnt there. Is there a way to release a software update to the camera to fix this? The note 9 and note 10 had the abilty to choose where to focus the super slow mo. As well as change the amount of time it would shoot for. Why does the more advanced model in the note series not have this option??
1 REPLY 1
Highlighted
Re: Galaxy Note 20 Super Slow Motion is not able to focus
It's likely due to the larger 108MP sensor
