Galaxy Note 20 Ultra 5G mobile signal issue
(Topic created: 03-27-2023 01:47 PM)
DVGalaxy
Note20
For the last few months, since I've upgraded to One UI 5.0, my phone has been losing mobile signal when I leave my home wifi. For instance I leave my home wifi, go outside and I have no mobile signal. I try toggling the mobile data on and off, still nothing. The solution that works is rebooting the phone. This also happenes while I'm on a train entering and then exiting a tunnel. I have no idea why this is happening, and this has only been occuring since the ONE UI 5.0 update, and it's extremely annoying. Is there any other solution than rebooting my phone to keep the mobile signal constantly working?
Samsung_Moderator
Note20
Hello, We understand how frustrating it is to lose your data connection.
Here are some tips that may help: https://www.samsung.com/uk/support/mobile-devices/how-to-troubleshoot-mobile-data-issues/
If you continue to lose the data connection, you will need to reach out to your service provider for additional assistance.
Yamialex224
Honored Contributor
Note20
Try getting a new Sim card. I had an issue like that when I had my iPhone. When I went from wifi to data it wasn't working. In my case verizon said it was an old and rare Sim card error
Samsung_Moderator
Note20
