Highlighted
High Battery use Note 20 Ultra
Has anyone experienced high battery use on their Note 20? This morning I had a full charge and without touching the phone it went down by 6% in less than an hour. Please advise if you have experienced this and what you did to fix the battery drain.
3 REPLIES 3
Highlighted
Re: High Battery use Note 20 Ultra
Device Care -> Battery -> Battery Usage... this will tell you where your drain is coming from.
Highlighted
thank you
Highlighted
That's crazy useage. Sounds like and app was misbehaving.
