- Mute
‎03-05-2022 10:05 PM (Last edited ‎03-14-2022 04:49 PM by SamsungJoJo ) in
Note20I lost my S pen to my Samsung S20 Note Ultra...will my S Pen work from my NOTE 8? It seems to fit just fine, but won't connect. Is there an app or something I need to do?
Solved! Go to Solution.
- Mute
‎03-06-2022 06:55 AM in
Note20@Gumbysstang The S Pen from the Note 8 doesn't have the Bluetooth capabilities of the Note 20's S Pen so you will never be able to connect it. It will still do simple operations like air commands. You won't be able to use air gestures.
- Mute
