My Galaxy Note 20 Ultra is rebooting itself over and over and it doesn't start.
(Topic created: 05-18-2022 10:09 AM)
Joaa
Note20
My Galaxy Note 20 Ultra is rebooting itself over and over and it doesn't start. It shows only Android Recovery screen which give 3 options.
1. Try again (it keeps rebooting itself).
2. Erase app data.
3. Power off (keeps rebooting)
4. View rescue log.
I can't afford loosing my data. So I'd be glad to receive any suggestions on how to fix this issue. Thank you
Samsung_Moderator
Note20
Hello, thank you for your feedback. I understand your frustrations with your Note rebooting repeatedly, and I am here to help. Third-party apps can cause random or constant reboots to happen on your phone or tablet. Follow these steps to troubleshoot this issue. You can perform a software update, factory reset, or turn on Safe mode to determine if an app is causing the issue. Here is a link with some additional information on resolving the issue
http://www.samsung.com/us/support/troubleshooting/TSG01001475/
userKYmtKmz7lk
Note20
, b
wow10
Galaxy
Note20
Partial clear cache,maybe
Charkatak
Black Hole
Note20
Have you had a backup enabled before issue started happening?
Joaa
Note20
Nop.
Samsung_Moderator
Note20
