Need help connecting my Gear 360 on my Note 20 ultra
(Topic created on: 4/25/21 1:47 AM)
userd5WxdSpPq7
Note20
I need help connecting my Gear 360 camera to my Nota20 ultra.  I can't find the camera app in the Galaxy store or play store.  hopefully someone can help.
nopen1278
Comet
Note20
I found the gear 360 app with a Google search but it appears samsung may need to update the software as it states my device in incompatible with my phone. I have the s21 ultra. Now is samsung going to update the software is a different question as the device is now 4 years old.
userd5WxdSpPq7
Note20
Thank you I will try and see if I can find it again but I haven't seen it and yeah hopefully they up date the app other wise I can use the camera just no viewfinder is all.
Members_j01REwi
Note20
All i can find is that Samsung no longer supports the Gear 360 camera and it is not compatible with my Note 20 Ultra. I am quite upset that I cannot use this camera any longer. Is there a fix for this issue? Or is Samsung just giving up on the 360 camera?
