No incoming calls or texts
(Topic created: 11-30-2020 08:43 AM)
userRIG8EvHnlo
Note20
Recently upgraded to an unlocked note 20 here in the US. Inserted my Lycamobile SIM, which worked very well in my older phone.  Data works perfectly OK. However, the RSSI bars are replaced with a crossed circle. SIM settings says "Not registered". Because of this I have no incoming calls or text. However, if i try to dial out a number, it does work and the RSSI bars do come on during the call.
Please help!
SamsungJoJo
Note20
I recommend reaching out to your current service provider for further assistance regarding your concerns.
1 Reply
SamsungJoJo
Note20
