Note 20 USB c and fast charging issues
(Topic created: 05-09-2021 09:09 AM)
dmorrissette
Cosmic Ray
Note20
Since last update my USB C cord only charges one way. Fast charging is also not working. I have tried multiple USB c to USB c cables. If I use a regular charger instead of a adaptive fast charger then the cable works no matter what direction. Any tips? I made sure the fast charging is enabled in the battery options.
 N986U1. I also cleared system cache.
dmorrissette
Cosmic Ray
Note20
I have. No luck.
dmorrissette
Cosmic Ray
Note20
DUD5 May security update.
