Note 20 Ultra Bluetooth sound quality
(Topic created: 11-22-2020 06:55 AM)
Cutttyg
Note20
Is it an app. Or anything I can do to improve the quality of my sound system as I am Bluetooth to the note20ultra? I have completely lost the ability to use my phone as the source of Bluetooth. I hate it . I completely take the SIM out and put it in my S7 to listen to music.... $1500 I should not have to do this!!!
userTcWMAWZeiT
Note20
Go to settings, sounds and vibrations, down to the bottom, separate app sounds.    Pick the app your using to listen to audio, then select your Bluetooth output device .
Toggle on, or back off, then on.
Which will cause a drop down notification asking if you want to "separate app audio?" Hit ok.  If Audio was playing, it will stop, then go back into your audio playing app, and hit play....
Only issue, is it has to be re done every time you reconnect to the device. Gets old....  But the audio went from clippy and tinny to good. Let me know if this helps
userTcWMAWZeiT
Note20
Cutttyg
Note20
thanks!!!! [ ; ) its sounds much better. still not like the S7. but I can live with it t..thanks!!!!!! your great!!!
