Note 20 Ultra Facial recognition problem
(Topic created on: 8/28/20 11:31 PM)
userCEh6LWciZm
Note20
My Note 20 ultra will not open with facial recognition.  I have tried setting it up 3 separate times and each time it tells me I was successful.  Yet when I actually try to open my phone using facial recognition instead of the fingerprint sensor it never opens.  I've tried it at different angles and in all different lighting and no success.  No once has it opened. Any suggestions would be greatly appreciated. Thank you in advance for any help.
userchaWQUron7
Note20
Having the same problem. The phone overall is fantastic however the facial recognition issue is a major put off especially when it comes down to a $1300 phablet. Very disappointed.
Only solution is to turn off the option of face unlock until samsung considers this issue seriously. IPhone never misses your face though!
Note20
Have you called technical support?  What did they say?  Just wondering.
userBbR5kSO46X
Note20
Same issue here in UK, never had a phone with this issue, I wonder if it is a hardware or software issue, had the phone 12 hours and did a factory reset, but that made no different, it going back under the 14days return policy
userqnXFkAh5eJ
Note20
same....coming from pixel 4 and one plus i cant believe how bad this is....it almost never works
Note20
it has to be at a certain angle.. have you tried it with different angles?
Note20
are you still having trouble unlocking the device using face recognition? report it via the Samsung Members app if you're still having an issue with it.
betaphex
Note20
same issue here, crazy I just gave up
userPEx2sAFNhW
Note20
Same issue. Facial recognition has never worked. I just took it seriously and started researching
SamsungAdam
Note20
Are you by any chance wearing a mask when you are experiencing these symptoms?
Have you tried adding your facial recognition at multiple angles?
