Note 20 Ultra Wifi issues
(Topic created: 12-21-2020 11:41 AM)
userxukyFVzyCz
Note20
Did anyone find a fix for this problem?
It is super annoying. Samsung for such an expensive phone you should fix this like yesterday!
mkoppler123
Cosmic Ray
Note20
if it's the issue with wifi dropping in and out. disable the google location accuracy under settings/ location. I guess it's an update that Google pushed recently that is the culprit.
user8qsb1m7bvF
Note20
I just changed the MAC address setting,  hoping that works. I read it worked for several people.
Open Connections> select your wifi SSID> select advanced> select MAC Address and change to use Phone MAC.
userxukyFVzyCz
Note20
Thanks. I tried it... It worked for 5 mins and then went back to the same issue.
mkoppler123
Cosmic Ray
Note20
userxukyFVzyCz
Note20
Thanks! This seems to be working. It is annoying to toggle this on and off since some apps need the location services to operate properly. I hope there is a permanent solution coming soon.
Rodi19
Note20
Thanks! I just turned off Google location accuracy. Samsung really needs to fix this issue. It's really annoying.
