Note 20 Ultra Wifi stops working started few weeks ago
(Topic created: 12-11-2020 07:46 PM)
kal0pr
Note20
My Note 20 was doing great but few weeks ago everytime Im connected to wifi, it stops working after 5-10mins.   So now I disable wifi.
1) I first reset the network and the problem showed up again.
2) Few days ago I did a factory reset and the problem showed up again.
All my other devices and phones are working properly in my home network so definitely a problem with this phone... I filed several error reports but I havent heard anything yet.... Will report back when I get feedback or update.
Thanks!
Edwin
pullenuk
Cosmic Ray
Note20
google location accuracy. Turn it off. Been mentioned elsewhere and this seems to solve it! Make sure you post if it works for you. If it does then we all need to tell samsung on the reports.
kal0pr
Note20
I just updated to Android 11 UI 3 .... hoping this solve my problem
kal0pr
Note20
Still noticing issues with wifi 🙄😒
wifi stays connected but no internet in the phone 😒
codyblue
Note20
I'm having the same issue
kal0pr
Note20
I did file several issues thru this Samsung member app that collects log etc ... so hoping to hear from them later in the week
pullenuk
Cosmic Ray
Note20
kal0pr
Note20
Let me give that a shot ... thanks I'll report back
kal0pr
Note20
Ok the suggestion below seems to work for me
Go to Settings -> Location -> Google Location Accuracy
and turn that Off
After that I havent experience wifi dropping
Im still "testing" but before it was pretty quick and its been at least a couple of hours now without issues.
Ill report back tomorrow
pullenuk
Cosmic Ray
Note20
Yup, solved it. Been connected for two days now and not seen any issues. Hoping this remains the case.
kal0pr
Note20
yes it looks like my wifi issues are resolved after turning that off Thanks
