Note 20 ultra Android 11 Mobile Hotspot Issues Connected, No Internet
(Topic created: 12-23-2020 06:10 PM)
usermMyCLJVQ5T
Note20
When I try to connect my Windows laptop to my phones hotspot. It connects but say connected no internet. I reset the network settings and wiped cached partitions as well as repairing all apps but it still doesn't work. Anyone have any thoughts? It seems to be a Android 11 bug, because my hotspot worked great before the update.
JUMP TO SOLUTION
Not applicable
Note20
I am on T-Mobile.
Note20
okay thanks for letting me know. im on att (factory unlocked note 20 ultra)
i was curious to see if it was carrier specific but i guess not 😕
Note20
FIXED IT!
( Found it myself, heres what Samsung didn't tell you )
Whats the fix? Duplicate your APN but add ",dun" to the end of the previous value under APN TYPE.
STEPS:
1. Settings > Connections > Mobile Networks > Access Point Names (aka APN)
2. Screenshot (scrolling capture to ease the process, open Gallery in floating window)
3. Click Add and fill in all the values properly as they were from your original APN.
4. Heres where we fix it. Under APN TYPE, edit the value by adding ",dun" (without quotes of course) to the end of it. Save your new APN.
Make sure you have selected your new APN from your list of access points.
For good measure (in case of issues), toggle airplane mode on then off (to reset connection).
Go test your hotspot now as it should be working.
Notice: Make sure you did not make a typo when duplicating your original APN.
Mohdsabbuba
Cosmic Ray
Note20
yes it's working again thank you very much, Unfortunately Samsung employees didn't have the correct answer they have less experience, you should be working for samsung
Note20
Glad i could help and thank you for confirming that its working on your end as well!
Thank you for that comment haha 🙂
Mohdsabbuba
Cosmic Ray
Note20
no thank you my bro
Note20
Mohdsabbuba
Cosmic Ray
Note20
I hope if you can help us with the wifi calling on factory unlocked phone note 20 ultra, I have att Sim, try to help all of us
Note20
I just typed out 400 chars (max limit apparently), hit post and of course this poorly built app gave me a server error and discarded my text [ whhhhy didnt i copy it before posting...]
So one sec while i try again lol
Mohdsabbuba
Cosmic Ray
Note20
ok
