- Mute
‎12-23-2020 06:10 PM in
Note20When I try to connect my Windows laptop to my phones hotspot. It connects but say connected no internet. I reset the network settings and wiped cached partitions as well as repairing all apps but it still doesn't work. Anyone have any thoughts? It seems to be a Android 11 bug, because my hotspot worked great before the update.
Solved! Go to Solution.
- Mute
‎01-06-2021 11:34 AM in
Note20THANK YOU SO MUCH!!! I was really upset by this glitch and just like that it's fixed. Very cool.
- Mute
‎01-07-2021
10:12 AM
(Last edited
‎01-07-2021
11:23 AM
by
SamsungAdam
) in
THANK YOU SO MUCH!!
I had the exact same issue and your solution fixed it.
May I ask how you figured this out?
- Mute
‎01-07-2021 12:14 PM in
Note20- Mark as New
- Mute
‎01-14-2021 12:22 PM in
Note20This worked. How did you ever figure it out? did you download config file for your APN from carrier?
- Mute
‎01-14-2021 12:31 PM in
Note20- Mark as New
- Mute
‎01-20-2021 06:15 AM in
Note20- Mark as New
- Mute
‎01-27-2021 07:45 AM in
Note20Hi, my apn settings are greyed out and I'm not able to change or add a new apn. Any suggestions? I'm on Sprint/TMobile. TIA
- Mute
‎01-27-2021 11:45 AM in
Note20- Mark as New
- Mute
‎02-16-2021 05:41 AM in
Note20- Mark as New
- Mute
‎02-16-2021 12:21 PM in
Note20
