Note 20 ultra Android 11 Mobile Hotspot Issues Connected, No Internet
(Topic created: 12-23-2020 06:10 PM)
usermMyCLJVQ5T
Note20
When I try to connect my Windows laptop to my phones hotspot. It connects but say connected no internet. I reset the network settings and wiped cached partitions as well as repairing all apps but it still doesn't work. Anyone have any thoughts? It seems to be a Android 11 bug, because my hotspot worked great before the update.
JUMP TO SOLUTION
usermzeJaY3BsM
Supernova
Note20
You have hijacked this thread.  This thread has nothing to do with WiFi calling being blocked by AT&T, please create another thread for that issue (despite several already existing)
Mohdsabbuba
Cosmic Ray
Note20
we have to figure out how bypass it and put it on
Note20
i just got an ota update. i now have wifi calling, factory unlocked note 20 ultra on att (i am shocked). thank you samsung 🙂
Alexrd11
Note20
yes, you did something on the update that now I don't have the hotspot. it isn't "carrier specific". It worked before the update, doesn't work after it. That puts the blame squarely on Samsung's update. Period. and I put my sim card on the note 10 that I have and still works. but when I switched to the note 20 it tells me that I don't have internet.
