Highlighted
Note 20 ultra battery not improved after October update.
After October update battery life has not improved instead its backup has reduced.  I also tried wiping of cache partition but still the battery has not improved. Any resolution on this issue...
8 REPLIES 8
Highlighted
Cosmic Ray
Re: Note 20 ultra battery not improved after October update.
the only way battery life would be improved by updating thru the software would be in the detailed updated description they give you in the update layout. samsung would say something like performance and security issues has been updated. and battery life has been updated to expand longer and your device will now run cooler. I haven't seen an update where it said battery improvements has been made in a long time. I have Note 10+ and battery life is superior. its been superior for me in the note series lineup since the launch of the bigger battery capacity of the note 9. this is one of the reasons why I haven't upgraded to the note 20 ultra. the other reason is the storage. I like my 256gb of storage
Highlighted
Galaxy
If you're in the US that update isn't available yet
Highlighted
Re: Re: Note 20 ultra battery not improved after October update.
it's available
Highlighted
Galaxy
oh really cause I haven't gotten any October updates at all
Highlighted
I have unlocked unit
Highlighted
Galaxy
Re: Re: Re: Note 20 ultra battery not improved after October update.
Oh that's why, I think they sent it to unlocked devices first
Highlighted
so compared to September update battery backup is less after October update
Highlighted
samsung should provide clear changelog
