Note 20 ultra max sd card speed supported.
(Topic created: 08-25-2020 11:39 AM)
userK4N7aIGkpf
Note20
Hello,
I am creating this to get a definiative support thread going for the sd cards the note 20 ultra actually sup[ports. I had reached out to tech support over chat before getting my phone and they swore the ultra supports UFS. I got one annnnnnd it does not support it. I called tech support today and I got it supports UHS and I asked UHS 1 or UHS 2. Yes was the answer. I am not in the mareket to blow more money on sd cards. What does the note 20 ultra actuallt support? Does it support UHS 2 with the extra row of pins or the slower UHS-1?
LongHiker
Legendary Samsung Care Ambassador
Note20
According to this site -> https://www.accessoriestested.com/best-microsd-card-for-samsung-galaxy-note-20-ultra-5g/
"Though Galaxy Note 20 Ultra 5G only supports UHS-I memory card, but you can still use much faster UHS-II memory cards. You can use these cards transfer data faster from your computers."
LongHiker
Note20
JamesMac
Note20
your phone should've came with one!
userr2hoiR7Y7w
Note20
NO WAY any samsung phone comes with a microsd card
