- Mute
- Email to a Friend
01-17-2021 06:48 AM (Last edited 01-17-2021 07:42 AM ) in
Note20Good morning, after i got oficial android 11 update, i have two problems, it happens very often, WHEN I GOT A NOTIFICATION, IN LOCKSCREEN, I CAN t SWIPE DOWN THE NOTIFICATION, is like there is not touch detection, YES IT WORKS SIDE TO SIDE, AND WORKS WIDGETS ON LOCKSCREEN, the only problem is that, I CANT SWIPE DOWN, after i unlock once or twice the phone, it works perfect, --
another bug is , in main screen , when i swipe down the notification, when i swipe once, is perfect, but when you do the second swipe down to see all the notification, it not appear complet, until you touch it and shows complete, , when you do two or three swipes, tl appear complete, always in the second swipe..
i try to unistall a lot of apps, and ( reestablecer ajustes), and the problem continius....
please help
