Highlighted
Note20 Ultra is disconnecting and reconnecting during charging
For the last 2 weeks, while charging my phone it keeps disconnecting and reconnecting. It's not only annoying but slowing the charging process. I've tried resetting, different charging cables, different charging positons... The only way to currently charge my phone to 100% is wireless charging, but it's slow and I travel all day and can not do this in my car. Is anyone else having this problem?
5 REPLIES 5
Highlighted
Re: Note20 Ultra is disconnecting and reconnecting during charging
Sounds like you need to get your phone repaired.
The USB-C port may be damaged.
Highlighted
I was thinking this too, but I did forget to mention that it charges perfectly for the first 5-10 minutes before toggling. Do you think it could it still be the port?
Highlighted
Comet
It could also be the case. It will disconnect if the cable doesn't seat fully because of size of opening on the case (if you have to push harder to connect the cable). If it does the same thing without a case, do what ScoobySnaxxz said.
Highlighted
Thank you, unfortunately not the case in this instance.
Highlighted
if u wanna sell it.. trade it... let me know
