Note20 Ultra slow to connect to mobile data and slow connection speeds
(Topic created: 04-16-2021 02:57 PM)
jegsurf
Cosmic Ray
Note20
I have a note 20 ultra and I have mobile network connection problems very slow to connect. I have all the bars and the 5G connection and can have a 70 to 80 dBm signal strength but still takes a very long time to connect and start loading data. I have had the phone since December and only about 3 times have I had speeds about 200 to 400. I live in Houston TX on T-Mobile. I bought my phone from Samsung unlocked
SamsungQue
Honored Contributor
Note20
I would like to look into this issue further for you. Can you send me a private message using this link here? (http://bit.ly/2HP0oRi) Provide the following information.
  • Model number
  • IMEI number
jegsurf
Cosmic Ray
Note20
I wish I would have returned it immediately instead of waiting for updates
SamsungQue
Honored Contributor
Note20
Have you tried swapping out the sim card in your phone?
jegsurf
Cosmic Ray
Note20
Yes I've got a new one two time. I got a new one three days ago and no luck.
jegsurf
Cosmic Ray
Note20
Once I was getting 20 to 40 mbps and I reset the network about 5 times by hitting the reset button again and again until it showed it reset it about 5 times. After that I got speeds of 200 to 400 mbps for a little while
SamsungQue
Honored Contributor
Note20
  • Model number
  • IMEI number
jegsurf
Cosmic Ray
Note20
Ok
jegsurf
Cosmic Ray
Note20
I sent it to you
SamsungRei
Note20
Thank you. We have received your private message and will follow up with you there.
AG6
Comet
Note20
Sometimes turning off 5G and going with LTE helps.
Settings>connections>mobile networks>network mode
