Replacement S Pen Note 20 U has not been able to connect
(Topic created: 07-14-2021 09:56 PM)
DearHectalia
Note20
I got a replacement Note 20U and the S pen has not been able to connect, after a restart, the phone's update. Any idea's on what i can do?
CoolmanNikolai
Cosmic Ray
Note20
Place pen into device. Then put into recovery mode and clear cache, dalvic if possible. Then reboot . If that doesn't work backup all data and reset.
Settings ...apps...pen app...clear data...reboot...
TheGalaxy
Black Hole
Note20
If it is not OEM, it doesn't have Bluetooth
MrJell_Lee
Nebula
Note20
great guidance by Coolman, if none of those steps help fix the issue, then you may need to contact Samsung Members post reproduction of the issue. They should be able to tell you if it's a hardware issue or software issue and provide an appropriate fix
