Replacement S Pen for Note 20 Ultra not connecting
(Topic created: 05-22-2021 04:33 PM)
gpress
Note20
My wife lost her S pen for her phone, and bought a replacement pen. When I follow the instructions to set up the new pen, I get the message "Couldn't connect to your S Pen". No matter how many times I try. I've tried restarting the phone as well and "Reset S Pen" in Air Actions. Any suggestions?
userbv5NeJ6ALr
Note20
Just put the s pen in the slot it should connect
CasperTrina
Note20
Nope doesn't work, I'm having the same problem 😕
RedDragon
Samsung Care Ambassador
Note20
Are you using OEM S-Pen? Some third party S-Pen does not have Bluetooth which is needed to register.
ChiefRightous84
Note20
I have the same issue lost my pen got a new one and it won't connect I have the Samsung s pen
AshNM
Note20
Where did you purchase yours? I've found some on Amazon but can't seem to find them anywhere else.
gpress
Note20
Yeah Amazon. Said it was the OEM kind and that it would work, but unfortunately it still won't.
AshNM
Note20
That stinks. Hopefully you can figure something out or at least return the one that doesn't work.
