Replacement S Pen won't connect to phone
(Topic created: 04-23-2021 03:30 PM)
Michellerf
Note20
Lost the spen that came with the phone.   Ordered a replacement.  The one I received worked and connected to the phone all except the blue tooth features.   Now the spen ain't even connect to the phone.
SamsungJoJo
Note20
Hello,
May I ask where did you purchase the replacement S Pen from?
Try giving this article here a look to see if this helps any: https://www.samsung.com/us/support/answer/ANS00080375/
SamsungJoJo
Note20
Hello,
Michellerf
Note20
Thank you
Michellerf
Note20
Amazon
Michellerf
Note20
Amazon
SamsungJoJo
Note20
Thank you for confirming this.
Have you tried reaching out to Amazon to see if they can offer any further assistance?
Michellerf
Note20
I have not but will consider it
SamsungAdam
Note20
Did you purchase a Samsung original S-Pen from Amazon as we can't confirm the compatibility of third party s-pens with our device.
Michellerf
Note20
The description stated samsung
Dan2025
Halo
Note20
Return spen get original spen samsung be little more be better off ok no worries 👍samsung.com order products day guide u call dem up also chat dem in morning tell me wat happens ok...
