My Galaxy Note 20 Ultra is rebooting itself over and over and it doesn't start.
(Topic created: 05-18-2022 10:09 AM)
Joaa
Note20
My Galaxy Note 20 Ultra is rebooting itself over and over and it doesn't start. It shows only Android Recovery screen which give 3 options.
1. Try again (it keeps rebooting itself).
2. Erase app data.
3. Power off (keeps rebooting)
4. View rescue log.
I can't afford loosing my data. So I'd be glad to receive any suggestions on how to fix this issue. Thank you
Samsung_Moderator
Note20
Hello, We understand how frustrating it is for the phone to randomly restart itself.
I would try wiping the cache partition on your device and see if that helps any.
- Turn off the device.
- Press and hold the Volume Up key and the Bixby key, then press and hold the Power key.
- When the Android logo displays, release all three keys.
- An 'Installing system update' message will show for 30 - 60 seconds before the Android system recovery menu options appear.
- Press the Volume down key several times to highlight wipe cache partition.
- Press the Power key to select.
- Press the Volume down key to highlight yes, them and press the Power key to select.
- When the wipe cache partition is complete, Reboot system now is highlighted.
- Press the Power key to restart the device.
You can also try the troubleshooting steps here: https://www.samsung.com/us/support/troubleshooting/TSG01001475
If the phone continues to restart randomly, it is recommended to have the phone evaluated at an authorized service center. You can use the following link to find a list of service centers near you that can do the repair: http://www.samsung.com/us/support/service/location or by contacting customer support at 1-800-726-7864.
For service outside the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html
userKYmtKmz7lk
Note20
, b
wow10
Comet
Note20
Partial clear cache,maybe
Charkatak
Honored Contributor
Note20
Have you had a backup enabled before issue started happening?
Joaa
Note20
Nop.
Samsung_Moderator
Note20
