S Pen Replacement not connecting through Bluetooth
(Topic created on: 3/26/21 10:10 PM)
LieutDansLegs
Note20
Ordered new S PeN  from the Samsung Store. I know the originals have Bluetooth. If I bought a replacement from Samsung you would think the replacement would.....well it won't connect. Thanks Samsung thirty bucks well spent.
Note20
You also do not connect the S Pen through Bluetooth (as CJ619 pointed out), instead you have to go to:
Settings | Advanced Features | S Pen | Air Actions | Three button menu (top Right) | Reset S Pen
Do this with the replacement S Pen in the "Garage" (inside the phone).
CJ619
Nebula
Note20
Check this out and see if it works for you
LieutDansLegs
Note20
Yeah I did but no luck ..if I keep the S Pen actions button off in the drop down menu it's ok
AshleyEst93
Note20
The note 9s pen isn't blueetooth at least i didnt know if it was
CJ619
Nebula
Note20
Most S pens are Bluetooth connected. You just won't see it in the Bluetooth settings, as its synced through the phone
Note20
