11-29-2020 06:01 PM - edited 11-29-2020 06:03 PM
Samsung Note 20 Ultra 5G phones Defective NO BLUETOOTH W/PC PAIRING
11-29-2020 06:26 PM
You are incorrect. The app uses Bluetooth only for the calling part of it. The other part is to connect with Wi-Fi.
11-30-2020 08:06 AM
Yes, suspect that Samsung only had a bad run of these, and all may not be defective as these are. To be determined.
12-08-2020 07:21 PM - edited 12-08-2020 07:22 PM
I'm having the same problem. The PC seems to think it has paired to the phone. But the phone does not.
2 weeks ago
12-15-2020 05:45 PM
12-17-2020 12:37 PM
which bt speaker? maybe your bt speaker has limited device it can be paired??
try to reset the bt speaker and pair again
or try download samsung members app and submit a ticket.
once you open, click +, then click error report
with bt speaker detail
