Samsung Note 20 Ultra Wifi 5Ghz Connection Problem
(Topic created: 05-15-2021 01:41 PM)
BlueHawk77
Note20
Hi all.
My Samsung Note 20 Ultra all of a sudden decided not to connect even more not to detect my 5Ghz home Wifi Network. I checked all the solutions listed, such as turning off location accuracy, dropping to LTE, turning on phone mac (instead of random mac) none works.
Can someone tell me an alternative solution ?
Thanks in advance...
SamsungRei
Note20
Try the troubleshooting steps here: https://www.samsung.com/us/support/troubleshooting/TSG01001559 If the issue persists, it would be recommended to have the phone evaluated by a certified technician. You can take the phone to any local uBreakiFix location to have it evaluated. https://www.ubreakifix.com/samsung
Nikiib
Cosmic Ray
Note20
I'm having the same problem with my galaxy note 20. It will no longer connect to my Lexus. It won't even find the Lexus Bluetooth connection.
Nikiib
Cosmic Ray
Note20
This all happened after the last update
user8WP3EaYmmn
Note20
Thrfl300000000000llllllllllllllllllllllbworrygeger
